Z-ULTRAT Plus
Z-ULTRAT Plus is a highly resilient ABS-based 3D printing filament. It’s perfect for functional prototypes or 3D printing complex moving mechanisms in one go. No matter the purpose, objects created with Z-ULTRAT Plus remain dependable through time. What’s more, this 3D printing material is unaffected by high temperatures and impacts. Its exceptional resilience allows for demanding tests conducted in adverse environments. The filament is also suitable for creating durable end-use parts for automotive industry and engineering purposes. Improved adhesion between layers reinforces 3D printed parts.
Combined with a water-soluble Z-SUPPORT Premium filament, Z-ULTRAT Plus is a reliable solution for 3D printing intricate, hollow objects. Dissolvable support structures allow stacking batches of parts on top of each other. This feature provides a fitting solution for cost-effective short-run production. Based on ABS, the material can withstand post-processing with acetone and mechanical treatment. Z-ULTRAT Plus 3D printing material is securely locked in a cartridge to ensure the highest quality of every print.
Available Colors
Graphite
Dedicated for Container Weight Diameter Extrusion
Zortrax Inventure cartridge 350 g ±5% 1.75 mm Single / Dual with Z-SUPPORT Premium
Zortrax M300 Dual spool 2000 g ±5% Single / Dual with Z-SUPPORT Premium or Z-SUPPORT ATP
Zortrax Endureal Single
Key Properties Metric Imperial Test Method
Flexural Modulus 1.51 GPa 219 ksi ISO 178:2011
Breaking Stress 31.32 MPa 4540 psi ISO 527:1998
Glass Transition Temperature 70.19° C 158° F ISO 11357-3:2014
Prototype of a heater valve 3D printed with Z-ULTRAT Plus. Improved durability allows for thorough testing in real conditions.
HEATER VALVE. Prototype of a heater valve 3D printed with Z-ULTRAT Plus. Improved durability allows for thorough testing in real conditions.
Applications
  • industrial prototyping
  • intricate constructions made of multiple elements
  • complex moving mechanisms
  • detailed architectural mock-ups
  • small elements rich in details
  • hollow end-use parts
  • models with complicated organic shapes, difficult to obtain by traditional methods
Your Privacy is Important
Cookies on our websites are used to improve your experience and make it more personal. Click "Accept & close" to agree to use of cookies. You can always change your privacy settings in Cookie Preferences. Read our Cookie Policy for more details.
