Zortrax 3D Printers
Explore the benefits of each 3D Printer
                            Technology:                            All
                            UV LCD
                            LPD Plus
                            LPD
                    Inkspire 2 NEW
Automated UV LCD Resin 3D Printer. A part of refined resin 3D printing system from Zortrax, powered by Henkel/Loctite and Forward AM 3D printing resins.
                                            Technology: UV LCD
                                            Material type: Resin (bottle)
                                            Build volume: 192 x 120 x 280 mm
                                            Layer height: 25, 50, 100 microns
                                            Connectivity: WiFi, Ethernet, USB
        Endureal NEW
Third generation industrial 3D printer with dual-extrusion system for processing high-temp filaments.
                                            Technology: LPD Plus
                                            Material type: Filament (spool)
                                            Build volume: 300 x 400 x 300 mm
                                            Extrusion: Dual/Single
                                            Nozzle diameter: 0.4 mm
                                            Connectivity: Wi-Fi, Ethernet, USB
        M300 Dual
A large dual-extrusion 3D printer with advanced safety systems preventing failed prints
                                            Build volume: 265 x 265 x 300 mm
                                            Nozzle diameter: 0.4, 0.6 mm
        Inkspire
Fast and precise resin 3D printer guaranteeing results' repeatability and quality of every print.
                                            Technology: UV LCD
                                            Build volume: 74 x 132 x 175 mm
        M200 Plus
High-performance 3D printer designed for 3D printing farms.
                                            Technology: LPD
                                            Material type:  Filament (spool) 3
                                            Build volume: 200 x 200 x 180 mm
                                            Extrusion: Single
                                            Nozzle diameter: 0.3, 0.4, 0.6 mm
        M300 Plus
Reliable 3D printer with the largest workspace among desktop class 3D printers.
                                            Technology: LPD
                                            Build volume: 300 x 300 x 300 mm
                                            Extrusion: Single
        Inventure
LPD Plus 3D printer with an enclosed printing chamber and dissolvable support system.
                                            Material type: Filament (cartridge/spool)
                                             Build volume: 135 x 135 x 130 mm
                                            Connectivity: SD Card
