Z-ESD
Z-ESD* filament gives your models electrostatic discharge protection particularly useful in the electronic industry. Its surface resistivity ranging from 10^6 to 10^9 Ω/sq eliminates the risk of damaging sensitive electronic devices. The filament protects your models against most acids, alcohols, and weak alkalies. Z-ESD is perfect for casings of delicate electronic and mechanical components working in an adverse industrial environment.
The 3D printing material is best for industrial applications, like casings, tools made ad-hoc, and production parts. Low shrinkage guarantees precise and risk-free 3D printing of large models. Z-ESD is available in black.
*Starting from June 22nd, two types of Z-ESD material are included in the range of our materials - Z-ESD and Z-ESD v2. Both have the same properties, however, as their printing settings differ - two profiles, Z-ESD and Z-ESD v2 are available in Z-SUITE. The spools of both Z-ESD types are tabbed accordingly, and we recommend making sure which one you're using by checking the material sticker and choosing the right printing profile. In case you're printing a .zcodex previously sliced for Z-ESD, slicing them again with the Z-ESD v2 profile is necessary for printing with the v2 material type.
Available Colors
Black
Dedicated for Container Weight Diameter Extrusion
Zortrax M200 spool 800 g ±5% 1.75 mm Single
Zortrax M200 Plus
Zortrax Inventure Single / Dual with Z-SUPPORT PREMIUM
Zortrax M300 2000 g ±5% Single
Zortrax M300 Plus
Zortrax M300 Dual Dual with Z-SUPPORT PREMIUM
Key Properties of Z-ESD Metric Imperial Test Method
Tensile Strength 32.88 MPa 4770 psi ISO 527:1998
Flexural Modulus 1.50 GPa 218 ksi ISO 178:2011
Glass Transition Temperature 79.93° C 176° F ISO 11357-3:2014
Key Properties of Z-ESD v2 Metric Imperial Test Method
Tensile Modulus 2.3 - 2.4 GPa 334 - 348 ksi DIN 53457
Glass Transition Temperature 80 - 90° C 176 - 194° F DSC
Casing for the bus pirate installed on a circuit board. The electrostatic sensitive device is protected by the casing 3D printed with Z-ESD material reducing the risk of damage.
BUS PIRATE. Casing for the bus pirate installed on a circuit board. The electrostatic sensitive device is protected by the casing 3D printed with Z-ESD material reducing the risk of damage.
Applications
  • industrial parts and tools
  • end-use parts
  • casings for electronic devices
  • parts required to be resistant to chemicals and electrostatic discharge
