Z-ASA Pro 3D printing material is a stable thermoplastic designed to withstand adverse environments extending the life span of your models. The material is highly resistant to changing weather conditions and UV light, which makes it ideal for outdoor applications. Z-ASA Pro guarantees your models won’t change color and physical characteristics even after extensive testing outdoors. High temperature resistance makes it possible to test models under direct sunlight with no risk of deformation and bleaching. Z-ASA Pro is also suitable for accurate 3D printing of large models due to low shrinkage and warping. The filament is available in multiple colors.
Available Colors
| Dedicated for | Container | Weight | Diameter | Extrusion |
| Zortrax M200 | spool | 800 g ±5% | 1.75 mm | Single |
| Zortrax M200 Plus | ||||
| Zortrax Inventure | ||||
| Zortrax M300 | 2000 g ±5% | |||
| Zortrax M300 Plus | ||||
| Zortrax M300 Dual | Single / Dual with Z-SUPPORT ATP |
| Key Properties | Metric | Imperial | Test Method |
| Izod Impact, Notched | 3.81 kJ/m2 | 1.81 ft-lb/in2 | ISO 180:2004 |
| Flexural Modulus | 1.36 GPa | 197 ksi | ISO 178:2011 |
| Glass Transition Temperature | 80.99° C | 178° F | ISO 11357-3:2014 |
TURBINE. Fully functional prototype of the wind turbine 3D printed with Z-ASA Pro filament. The model stays unaffected by the changing temperature, humidity and light, allowing for a prolonged field testing.
Applications
- Models tested outside
- Objects required to be resistant to the changing weather conditions and UV light
- Functional outdoor prototyping
- Large-scale models
- Automotive parts
Weather resistance
Weather resistance of Z-ASA Pro filament allows for testing your models outdoors. 3D printed, highly durable prototypes and final parts can work even in direct sunlight.
UV stable
Z-ASA Pro won’t deform or fade when exposed to the heat. Conduct thorough outdoor tests, no matter the changing temperature and direct sunlight.
Low shrinkage and warping
The polystyrene-based filament is also available for Zortrax M300, which makes it ideal for large casings and parts. Its low shrinkage and warping guarantee dimensionally accurate 3D printing.
