Enterprise 3D printing services
Zortrax 3D printing services is an on-demand manufacturing service aimed at both enterprises and individuals. Customers' designs are fabricated on Zortrax 3D printers operated by a dedicated team of professional 3D printing engineers and shipped to any chosen place in the world.
Zortrax 3D printing farm. Zortrax 3D printing services work with a cluster of over 200 3D printers.
Your benefits
Fabrication with 3D printers can be done with shorter lead times compared to injection-molding because there is no time necessary for tooling. Production can start almost immediately.
3D printers can produce almost all shapes out of a wide variety of materials. It is possible achieve desired chemical and mechanical properties in any given design.
Rapid prototyping and short-series production are applications where 3D printers are significantly more cost-efficient than traditional manufacturing techniques.
3D design
Optimizing designs for a chosen 3D printing technology.
Consulting and training
Professional consulting and training on 3D printing technologies.
Low volume manufacturing
Cost-efficient, low-volume manufacturing service.
Reverse engineering
Reverse engineering parts based on existing products.
Our 3D printing technologies
Choose the best 3D printing technology for your project.
| LPD | LPD Plus | UV LCD | |
| Max build volume | 300 x 300 x 300 mm | 265 x 265 x 300 mm | 192 x 120 x 280 mm |
| Accuracy | 0.09 mm - 0.29 mm per layer | 0.15 mm - 0.2 mm per layer | X/Y axes - 0.05 mm; Z axis - 0.025 - 0.1 mm per layer |
| Supported materials |
Z-ABS, Z-ASA Pro, Z-PETG, Z-GLASS, Z-PLA, Z-NYLON, Z-FLEX, Z-HIPS, Z-PLA Pro, Z-PCABS, Z-ESD, Z-ULTRAT, or third-party equivalents. |
Z-PETG, Z-PLA, or third-party equivalents. | Zortrax Resin BASIC, Zortrax Resin TOUGH, BlueCast, Raydent, Henkel/Loctite, Forward AM |
| Applications |
| Advantages | LPD technology is the most cost-efficient for making medium size simple products like lamps or remote controllers. Models can be automatically vapor smoothed for superior surface quality and finish. | LPD Plus technology is best for intricately designed, medium size parts like movable mechanism or organic shapes. Models can be automatically vapor smoothed for superior surface quality and finish. | Resin 3D printing technologies like the Zortrax UV LCD are best for small yet complex products made in high quantities. Models fabricated with biocompatible resins must be sterilized before use. |
Place your order
Fill in the form below to get a quote.
Thank you for using Zortrax 3D printing services.
We are processing your order. Our representative will be getting in touch with you shortly
